JOter
7 years agoSet_output_delay commands does not apply to the output signal
We have a design where we control an external RAM memory. We generate the CLK and control memory signals in a FPGA (Cyclone IV). The CLK signal is generated using a PLL, with 180º phase shift. The ...
KhaiChein_Y_Intel
7 years agoHi,
What is the max and min output delay? Is it within range?
Can you report Ignored Constraints and see if the set_output_delay constraint is being ignored?
