17 years agoOk, i have now found out that the LAI output DOES add a fair amount of delay compared to the actual output pins. This means Quartus, the Classic Timing Analyzer, TimeQuest as well as you has been right all along. Thanks for pointing me in this direction - i had assumed that the LAI had much less latency...
When measuring directly on the output pins i am meeting the I/O constraints with 1 ns to spare (th for the SLWR signal). The other worst-case slack ranges from 2.5 to 3.3ns. I have enabled "multi-corner analysis " in the settings dialog, what other settings must i do, if any) to ensure that my timings are correct for slow/fast devices? Thanks, /John.
