17 years agoWhen you say I/O timing, do you mean through the LAI interface or what TimeQuest reports. The path I looked at added a 13ns route to your output path, which is something I have never seen done before, and I am certain is due to your timing constraints. So I still don't see the problem as it looks like what is occuring is correct(and impressive, as adding delay used to be very difficult for any FPGA fitter just a few years ago).
You say adding 2-5ns would do, but you're saying it has to add 2-5ns across all timing models, which is difficult to do. My feeling is that you're trying to do something difficut(interface to a RAM that just isn't made to run at 48MHz), but it might be possible. What are the SLWR signals slack for setup slow model and hold fast model? You could attach those too, but it's a very tight window you're shooting for.
