17 years agoThanks FvM and Rysc. Your feedback here is much appreciated. I'm still getting up to speed on FPGA best practices and your comments are invaluable.
What still confuses me is that if i don't constrain my I/O at all i'm approximately getting the same I/O timing as when i specify the SDC that was posted. It is the hold timing that is not met (around 2-3 ns regardless if the I/O is constrained or not). Since the SLWR signal requires 13 ns setup time and 4ns hold time , this is what i put into the SDC. The same goes for the DATA_OUT bus but that has much less stringent tsu. So, basically, i just want to delay the SLWR and DATA_OUT signals a few ns (2 to 5 would do) so that the th is met. That however doesn't guarantee tsu unless it is also constrained. This brings me back to the original problem with how to set up the SDC. I'm hoping you see the problem and can give me some hints how to properly constrain this I/O. It seems like playing with the clock signal is not the correct method when the data timing is only a couple of ns off.
