The clocks always relate back to the original input. If it doesn't the different delays can cancel out. (Let's say your clock and data were created from two different PLLs. If it ignored the delays up to the PLL, then you would have incorrect timing analysis since they would be slightly different. This is best practice, and in the case where that delay is the same for the data and clock, they both just cancel out and there is no problem. Note that it doesn't say your clock to out is 17ns, that's the information I pulled out of it(and it is adding 13ns of routing delay, so it's somewhat accurate). What TQ is telling you that when you launch data from time 0ns, it gets out there after the clock launched at time 0ns, including your -min delay requirements, which is what you want.
I ignored your SLWR signal's requirement, or at least wasn't thinking about it. You've got a 20ns clock period, and this signal chews up 13ns for setup and 5ns for hold, allowing the FPGA to try to align the clock and data with a max difference of 2ns. I hate to say it, but that's probably not going to happen. You really have too slow of a memory. You'll probably either need a faster run, or make this particular path a multicycle(i.e. when you send data on that line, you don't expect it it reach the destination for 2 clocks). I don't know the behavior of this signal to know what it's affect will be. And probably the reason doubling your set_output_delay didn't have as great affect is that it's already doing everything it can. Like I said, it's adding 13ns of routing delay already, which easily meets timing in the slow corner, but probably doesn't meet by much in the fast corner. This is why "adding delay to meet timing" can only go so fast, because the slow and fast corners can differ by a lot. When the clock and data paths are aligned, then the paths will still vary a lot, but they vary together and everything works out nicely.
