fpgauser
3 years agoset_max_skew timing issue for DDR2 emif on MAX 10
I have a timing issue on my design using DDR2 controller on max 10 fpga. In the generated sdc file for the DDR2 controller I have two skew constraints (cf. below):
- 3 years ago
Hi Amine,
I'm agree with your assumption.
Since this is a soft controller, the timing constraint that has been generated may not fix to the design.
I think you can increase the max skew to meet the timing requirement for each port.
Adzim
sstrell
3 years agoIt's difficult without seeing the project or the timing report errors, but I'd guess the I/O locations you've selected are causing the issue. The Fitter can't meet the requirements to the pins you've selected. This is MAX 10, so I'm guessing this is a soft controller so it could be placed anywhere in the device. Check how the Fitter is placing the controller logic. There may be some other constraints on placement.
