JayHarikumaran's avatar
JayHarikumaran
4 years ago
set_max_skew giving path not found warning
I have a set of signals passing between asynchronous clock domains in an spi slave module.
I get the following warning when i try to add the max skew constraint
Warning (332182): No path is found satisfying assignment "set_max_skew -from [get_keepers {*spi*shift_reg*}] -to [get_keepers {*spi*rx_data_reg*}] -get_skew_value_from_clock_period min_clock_period -skew_value_multiplier 0.800 ". This assignment will be ignored.
The exact command from the sdc file is also included
Jay
  • SyafieqS's avatar
    SyafieqS
    Hi Jaya,
    You might need to see below KDB which affect 20.4 and prior Quartus user. This may affect the source destination when trying to set the skew of your constraint. Can you try instead of specify get_value_from_clock_period dst_clock_period -value_multiplier 0.8, you put the value straight away but this time applied to set_max_skew constraint and see if it applicable. The reason is set net delay are able to work for above KDB when specify the value directly.
    https://www.intel.com/content/www/us/en/support/programmable/articles/000085880.html
    • JoseTdeSousa's avatar
      JoseTdeSousa
      I had a similar issue: it happens in Standard Edition 18.1 -- 20.1, but does not happen in Quartus Pro 22.2
      set_clock_groups -asynchronous *does* impact set_max_skew on Standard 18.1-20.1 but not on Pro 22.2
