set_max_skew giving path not found warning
- 5 years ago
Hey,
I have the exact same problem. https://community.intel.com/t5/Intel-Quartus-Prime-Software/Crossing-Clock-Domain-Problems-Timing-Analyser-ignores-set-max/td-p/1308590 .
However it works during the place and route and also the designs output is correct. I can not detect any metastability.Am I right assuming that this error just occurs while using the Timing Analyser and no error is thrown during compilation?
Sadly I also got no answer as do other people with the same question (looking through the forum it gets asked at least once a week I would say).
Best regard
Christian
Hi Syafieq,
I couldn't find the Node finder in TA. I can see that option in RTL viewer. Is that what you meant?
I reran the SDC file by removing the asynchronous clock grouping and the skew command was executed and didnt generate a warning.
set_clock_groups -asynchronous -group [get_clocks {spi_clk spi_virt_clk}]
set_max_skew -from [get_registers {*spi*shift_reg[*]*}] -to [get_registers {*spi*rx_data_reg[*]*}] -get_skew_value_from_clock_period min_clock_period -skew_value_multiplier 0.8
