JayHarikumaran
5 years agoset_max_skew giving path not found warning
Hello, I have a set of signals passing between asynchronous clock domains in an spi slave module. I get the following warning when i try to add the max skew constraint Warning (332182): No pat...
- 5 years ago
Hey,
I have the exact same problem. https://community.intel.com/t5/Intel-Quartus-Prime-Software/Crossing-Clock-Domain-Problems-Timing-Analyser-ignores-set-max/td-p/1308590 .
However it works during the place and route and also the designs output is correct. I can not detect any metastability.Am I right assuming that this error just occurs while using the Timing Analyser and no error is thrown during compilation?
Sadly I also got no answer as do other people with the same question (looking through the forum it gets asked at least once a week I would say).
Best regard
Christian
SyafieqS
5 years agoJay,
Can you set the max skew again and this time using node finder in TA to verify the path?
