12 years ago
Set_input_delay misunderstanding
Hello:
new to sdc constrains
I have 2 cases to constrain my serial data coming in and trying to understand the differences
Case 1 has been done in previous projects right or wrong but shows no timing violation. In my project I am getting a small negative slack for hold time (on Fast timing)
Case 2 shows no timing violation (positive slack)
This case was created based on reading the Timequest user guide. However, I don't understand how RX_CLK relates to the virtual clock
It seems that the total tCo in one case should be different to the other on default relationships??
Which one is correct? For me, case 1 ties directly to the clock input on the FPGA and the tCo should account for board delays , margin and the spec tCo of the device.
FPGA input is
RX_CLK -Pin
RC_Data0- pin
tComin and tComax are defined
RC_Data0 should be clocked into a shift register in the RX_CLK clock domain
Case 1
create_clock -period 20 [get_ports { RX_CLK }]
set_input_delay -clock { RX_CLK } -clock_fall -min -$uC_tCOmin [get_ports { RC_Data0 }]
set_input_delay -clock { RX_CLK } -clock_fall -max $uC_tCOmax [get_ports { RC_Data0 }]
Case 2
create_clock –name RX_CLK _Virtual -period 20
set_input_delay -clock { RX_CLK _Virtual } -clock_fall -min -$uC_tCOmin [get_ports { RC_Data0 }]
set_input_delay -clock { RX_CLK _Virtual } -clock_fall -max $uC_tCOmax [get_ports { RC_Data0 }]
thank you
    --- Quote Start ---
    Hold violations are restricted Fmax? I haven't seen this, but not sure how it would work. A hold violation within a domain basically means it can't run at any rate, i.e. even 1 Hz. So not sure how it would show the magnitude of failure without a negative number or something strange like that.
    --- Quote End ---
    Rysc please look here:
    http://quartushelp.altera.com/11.1/mergedprojects/tafs/tafs/tcl_pkg_sta_ver_1.0_cmd_get_clock_fmax_info.htm
    I will leave you guessing what this type of hold violation actually is...
    --- Quote Start ---
    --- Quote End ---
    I will add a clue that we are talking about two cases of hold violations and both should be reported in slack:
    case1 : the old concept which does not depend on speed as you mentioned but is caused by skew thingy and does not restrict fmax which is only dependent on setup slack
    case2: not skew related, affects speed and is reported in both slack and restricted fmax.
    Hi Rysc and kaz;
    My obvious mistake was the syntax error caught by kaz on the "-" in front of the timing delay. Once I fixed this, my hold time violation went away. I did try using a virtual clock and the slack results were almost the same. In either case through the different discussions in this thread, I have learned a lot .
    Rysc :
    a) you have described the case where the FPGA sends the clk to an external register and how you setup your. If the clock and data are generated by the external device (asynchronous to any clock on the FPGA) , how will the constrains set_input_delay,set_output_delay change assuming the spec from the Ext device give you tCo min max for data respect clk
    tH min for data respect to clk
    thank you
    thanks
