10 years agoset_input_delay constraint
Hi, I have a bidirectional synchronous interface which I want to constrain. Without any constraints the interface doesn't work and with the constraints I tried it works, but I get the message f...
10 years agoIt seems that the data delay is too long with the clock and input delay and it works because the delay is in fact not as long as I told Quartus.
I think I that I have to redesign the whole state machine including clocks. After I combined my two FSMs for reading and writing with a FIFO to a loopback the reported FMAX is lower than my clock and output delays of some data pins can not be met. Before I start I have some questions: The interface has a maximum tCO of 7 and 8ns (data/flags). And a tCDH (clock to data hold) of 2ns. At the interface clock of 100MHz I only have a data valid window of 5ns around the clock. Currently I have the fpga_clock and the inverted fpga_clock as PCLK and no output registers. Then my setup relationship between launch and latch clock is for outgoing data is 5ns, right? Would it be better to add a register to every signal going to the interface? This way I would have a looser setup relationship? How can I constrain that I only have a data valid window of 5ns? If I have a clk100 generating the data and control signals for writing to the interface and a clk100_shifted clock to meet setup times on the interface side and another phase shifted clock for clocking in the data read from the interface. Couldn't I get problems with setup times between the clk100 and the clock latching the the FLAGS/data from the interface because I need to read the signals in the clk100 domain. Thank you for your detailed answers!
