set_global_assignment -name ENABLE_PR_POF_ID OFF
Over 100 PR regions?! I can't imagine how or why you would create a design like that or even manage it.
But for your question, if .rbf files are not getting generated, there must be other warnings or information about why that is. The Assembler should still create them. Turning off this one option shouldn't prevent that.
And as far as compile time, compilations with partitions and LL regions will always take longer because of the additional checking, preservation, and restrictions required by the compiler for that type of design vs. a flat design where the tool can put design resources anywhere it wants.
Never mind, I was able to generate .pmsf file and .rbf file with a new project. I may have made a mistake creating a revision in the previous one.
The long compile time with the assembler isn't resolved though.
