Altera_ForumHonored Contributor14 years agoSet false path in VHDL file instead of .sdc file Hi everyone, I was wondering if it is possible to set a "false path" attribute in VHDL instead of doing it in the .sdc file? I know it was possible with Xilinx, you could add a "TIG" attri...Show More
Altera_ForumHonored Contributor14 years agoyou'll have to tweak it for VHDL: http://www.alteraforum.com/forum/showthread.php?t=24028
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
