16 years agoWhat rbugalho is right on. You do not have to set multicycle path constraints on a path by path basis. There are a number of ways to do so. For example, one technique would be to set the constraint for an entire clock domain. As I stated earlier, beware...you need to verify that your enable path is still timed as a single-cycle path.
Agree with rbughalo comments on area. Optimization to meet a higher frequency may require techniques that cause area increase.
