16 years agoThanks for details explanation. I learn a lot..
Some fact confuse me: "the P&R tools will attempt to optimize your design so that paths between FF's are minimized to meet 200MHz timing" causing area bigger. From my point of view, if paths between FF's are minimized to meet 200MHz timing, then the area should be getting smaller instead of bigger due to the FF related have to placed closer, shortening the length of wire. Pls correct me if i am wrong.. Question: In the case of setting multicycle for the path related, then it would be a lot. It is because my whole project is done like this(using clock enable). So, any efficient way like to set multicycle for whole design except the frequency divider? thanks
