--- Quote Start ---
so what you say is period of 0.1 msec is actually 0.2msec
--- Quote End ---
Sorry for that, you are right! the period was intended to be 0.1ms NOT 0.2 so I reduce the divisor to 2499 and its already working. What I don't really understand is why I have to divide the divider by half, for example if I have a 50MHz clock and it needs to be down to 10KHz, the divider is 5000, right. I understand the code takes a count every rising edge, but if I need 5000 cycles of 20ns (50MHz) to get a 0.1ms period signal why do I need to specify the divider as 2500 if in 5000 cycles, there are 5000 rising edges!
