AGrim
8 years agoSerial Flash Controller II - Multiple Subsystems
Hi All, I am using Quartus Prime V18.0. I have a Serial Flash Controller II talking to my EPCQ(ASx4). I have two subsystems that each have a NIOS II CPU in them. One system is of my own design, the ...
AGrim
8 years agoHi,
By "locked down" I mean that the IP I am using requires the subsystem to match exactly to the documentation; I do have full access to how the buses are hooked up. The NIOS II code for that CPU/subsystem is pre-compiled (communications stack) and I am only provided the image, thus the QSYS must match exactly.
After some investigation it seems that swapping in an Address Span Extender may have solved the issue. I need to do some more reading as I'm not entirely sure how this is solving my problem ( the EPCQ driver is now showing up in my BSP project).
Andrew
