Altera_ForumHonored Contributor13 years agoselecting parameter based on reg value - verilog Hi , I have a set of parameters ( constants ) . I want to select one parameter at a time based on a register value (ex. reg [3:0] sel_value ) . Or i need to conditionally instantiat...Show More
Altera_ForumHonored Contributor13 years agoTHanks for the reply . Can you please suggest me with an example or sample code ?
Recent DiscussionsQuartus Lite 23.1 MAX 10 EncryptionHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:
