14 years ago
Selecting Assignment names in Assignment editor of Quartus II
Hi friends,
Is there any document/resource to learn about,how to select appropriate assignment names for the pins in Quartus II assignment editor?
for example( location,if we want to give exact pin)..etc.
Please reply me,if anyone knows about this?
Thanks in advance.
Raghavendra.S
    Hi the brick,
    Thanks for your reply.
    But my question was different.For example,there are many assignments like Location,PCI/O,current strength,slew rate,virtual pin,I/O standard..etc)
    I know the usage of "Location" which is used to assign exact pin location.even i did use "current strength with 12ma"for DDRSDRAM pins(it is suggested in kit user guide only) in my design.Like that ,i need some resource/links to learn about all assignment names.
    Thanks & Regards
    Raghavendra.S
    well, in the assignments editor you have the information window which gives some basic information (surprise) about every assignment.
    I believe that the most used for synthesis are
    set pin location
    current strength
    weak pull up
    and you might find this one also useful:
    set virtual pin
