10 years agoselect a component generated by gernerate stsement
hi im new to vhdl programming. i have a component ------comp port map (a(I),S(I), k);---- in file 1 which is generated 8 times by generate statement and in file 2 sub1 (file 1) is instantiate...
10 years ago? from your question it is unclear what strategy you try to use to acomplish problem.
Try simple multiplexor , change sub1 entity design Draw a port connectivity diagram that you await to clarify your question
