10 years agoseems timeQuest bug in Setup Relationship
I generate two clocks from a 288MHz input clock, one is 96MHz with -30 degree phase shift and another is 288MHz with -90 degree phase shift. Why timeQuest set 'setup relationship' to 0.001ns during timing analysis?
http://www.alteraforum.com/forum/attachment.php?attachmentid=11662&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=11663&stc=11 Reply
Rounding error. If you look at the actual launch and latch edges, they're off by 1ps. This was improved on in TimeQuest a few releases ago, so if using something years old, it might be fixed, but there can still be problems. Using clocks that are multiples of 3 is pretty uncommon. Sometimes tweaking the input clock frequency by a ps or two fixes it.
