DrewBaden
7 years agoSee "details".
# Reading D:/Altera/13.1/modelsim_ase/tcl/vsim/pref.tcl # do top_run_msim_rtl_verilog.do # if {[file exists rtl_work]} { # vdel -lib rtl_work -all # } # vlib rtl_work # vmap work rtl_work # ...
bitwise
7 years agoDrew,
Look in the installation path where you installed Modelsim-Altera. Based on the details in your script I'm guessing it's in "c:/Altera/13.1/Modelsim_ase/docs/pdfdocs". There should also be html format documents you might want to reference such as those in "c:/Altera/13.1/Modelsim_ase/docs/tcl_help_html/contents.htm".
