11 years agoSecurely start a State-Machine with pulses or edges
Hi there, this problem occures in my work from time to time: I want to start a State-Machine (Transition from Idle-State S000 to State S010) either with a single one-clock-pulse or on the edg...
11 years ago --- Quote Start --- This is something I normally don't use --- Quote End --- For any asynchronous input it is a must. --- Quote Start --- But I think my filtered edge-detection is somehow similar to that. --- Quote End --- No it is not unless you use the output of second synchroniser and discard others in the synchroniser chain. --- Quote Start --- The problem is between two cores inside the FPGA. Both cores are on the same clock and are working on the same edge (falling_edge). So I think the signal must already be synchronized. --- Quote End --- still it does not explain how the start_in comes in.
