11 years agoSecurely start a State-Machine with pulses or edges
Hi there, this problem occures in my work from time to time: I want to start a State-Machine (Transition from Idle-State S000 to State S010) either with a single one-clock-pulse or on the edg...
11 years agoyou assume - how do you know?
do you have a full verification testbench? have you got one that tries to do bad things in bad states? If everything is on the same clock - then the only answer is that its a code bug. Simple as that.
