11 years agoSecurely start a State-Machine with pulses or edges
Hi there, this problem occures in my work from time to time: I want to start a State-Machine (Transition from Idle-State S000 to State S010) either with a single one-clock-pulse or on the edg...
11 years agoI can't agree with you because the core normally starts ery well, except for about 1 out of 100 to 1000 tries. This could be caused by a clock-glitch, but they are on the same clock, so there can be no glitch.
If my state-machine is kind of messed up, wouldn't this cause much more errors? Besides, I've already checked if the state-machine is in an other state than the idle-state when the Start_IN comes. -It isn't. My cores process a message from outside the FPGA. The outside "Logic" (Processor) sends one message and the waits for the result (answer-message) before sending the next message. If the processor is done receiving the answer, every core in the FPGA is already in idle-state. So I assume the state-machines are working well. Except that it can occure, that one of the cores seems to "miss" its start-signal and so the message is lost.
