Secure Jtag on Max 10 ---
Thank you for answering my question, Please let me clarify,
It is easy to create the POF with JTAG -enable in Quartus tool (using convert file) of the document above.
1) Page 55. after power up and configuration of the JTAG-ENable. POF, MAX 10 is in JTAG secure mode.
page 56 To disable if "trigger the start_unlock port of the user logic) and issue UNLOCK JTAG INSTRUCTION.
The device exits from JTAG secure mode.
Do I need to pull nConfig pin LOW ? (page 28 describes configuration sequence) . or do anything with nStatus, CONF_DONE?
2)
After I enabled the JTAG secure mode, power off and on. I can't erase, configure or program the MAX 10 any more.
I pull on the UNLOCK I/O pin HIGH, it does not work. I send in UNLOCK instruction via
test_unlock using
quartus_jli -c 2 unlock_208.jam -a unlock
Info: *******************************************************************
Info: Running Quartus Prime Jam Tools
Info: Version 18.0.0 Build 614 04/24/2018 SJ Standard Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Mon Sep 23 16:36:14 2019
Info: Command: quartus_jli -c 2 unlock_208.jam -a unlock
Info: Using INI file /opt/intelFPGA/18.0/quartus/linux64/quartus.ini
Exit code = 0... Success
Info: Quartus Prime Jam Tools was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 194 megabytes
Info: Processing ended: Mon Sep 23 16:36:17 2019
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:0
'Altera 2016
'Purpose: To unlock
ACTION unlock = DO_UNLOCK;
PROCEDURE DO_UNLOCK;
DRSTOP IDLE;
IRSTOP IDLE;
STATE IDLE;
IRSCAN 10, $041;
WAIT 100 USEC;
EXIT 0;
ENDPROC;
