17 years ago
sdram tunning
hi
I use EP2C20Q240C8 with a 32 bit sdram
when I use pll number 2 (pin 177 is pll_out
that connected to sdram clock and pin 178 is
connected to sdram clock enable . Nios 2 program
is verified but the program doesn't execute .In the
other case when I use pll number 4 and sdram clock
is pin 177 and sdram clock enable is pin 178 Nios 2
program execute .Why the pll number 2 doesn't
work.I test this problem for variety of pll phase shift.
    hi
    I solve this problem with change the pll in ep2c20q240c8
    this down with changing the clock input.
    Hi jamshid
    Did u change the clock input to be in the same bank as that of the PLL output?
    --- Quote Start ---
    hi
    you must change the clock in the other bank.
    --- Quote End ---
    Which PLL on the chip are u sing..if it is PLL2, did u put the clock to be pin 154 and the PLL output to be 177?
    hi
    I can't work with pll number 2 .
    I put the clock to pin 91 and sdram clock to pin 177.
