Dolemy
3 years agoSdram error on DE2 - 35
Hello.
I am learning about design through the DE2-35 board recently.
I used NIOS II processor to use sdram.
For this, I used the sdram controller ip and set it within my knowledge range.
KellyJialin_Goh
3 years agoHi,
Greetings and welcome to Intel's Forum.
This error message indicates that you are using an old cygwin on a newer windows version. You may download a newer cygwin version here: https://www.intel.com/content/www/us/en/docs/programmable/683187/20-1/installing-cygwin.html
Do take note that you have to remove your current old cygwin version to avoid errors and only remain one installation. If this issue continues to persist, you may need to contact the cygwin team.
Hope to hear on your feedback.
Thank you.
Kelly
