9 years agoSDRAM Controller will be dropped from Quartus Lite!!
I just spotted this warning in QSYS:-
"sdram controller will only be supported in Quartus Prime Standard Edition in the future release." Any thoughts / suggestions??4 Replies
Stick to Quartus Prime Standard Edition in the future.
Cheers, Alex - Altera_Forum
It's £2,340 (Digikey# 544-1247-ND) for Quartus Standard- Node locked !
IPS-EMBEDDED might be cheaper ... (Mouser# 989-IPS-EMBEDDED, £786) Embedded IP Suite: A value bundle that contains licenses for the Nios II processor IP core, Triple-Speed Ethernet IP core, 16550 compatible UART and high-performance , DDR/DDR2/DDR3 SDRAM IP cores and high-performance DDR SDRAM IP core - Altera_Forum
There's nothing wrong with sticking to the version of Quartus you're currently using. Altera support plenty of devices that are only supported by older versions of the tools.
--- Quote Start --- There's nothing wrong with sticking to the version of Quartus you're currently using. Altera support plenty of devices that are only supported by older versions of the tools. Cheers, Alex --- Quote End --- The good news about 16.1 is: Info (20030): Parallel compilation is enabled and will use 4 of the 4 processors detected With 16.0 it was telling that the parallel compilation is not licensed (I am using free lite version).
