jrrguzman
8 years agoSDC ordering in script generated QSF file.
Hi, I'm using Quartus 17.0 and I'm trying to automate a project build with a TCL script. I got a SDC file which depends on some IP generated QIP files. In my script I add them to the QSF way before...
GuaBin_N_Intel
Contributor
8 years agoYes, script is executed sequentially. To debug the issue, you can stop both step 5 & 6 and check result after step4 . Each of project should load one .qsf at a time from the .qpf.
