8 years ago[SDC] Input/Output delay for All ports -> script writing
Hi All, How can I create the timing constraints (set_input/output_delay) for all ports (excepting clocks and reset ports)? Let's say the design has the following clocks: clk0, clk1, clk2 ...
8 years ago --- Quote Start --- where do you run the script? from outside of the Quartus? But ow can I run the same commands from the TCL Console (from inside of Quartus)? --- Quote End --- As I indicated I run the commands from the command line using this command:
quartus_sta -t generate_timing.tcl MY_DESIGN 10 so the tcl script is fed to the Quartus Static Timing Analyzer (quartus_sta) application. So basically the tcl command script in the file is run on the TCL console within the quartus_sta application.
