8 years ago[SDC] Input/Output delay for All ports -> script writing
Hi All, How can I create the timing constraints (set_input/output_delay) for all ports (excepting clocks and reset ports)? Let's say the design has the following clocks: clk0, clk1, clk2 ...
8 years ago --- Quote Start --- I tried to run the ferst example: ---------------------------------------------------------------------- set chan [open "TQ_all_clocks.rpt" "w"] foreach_in_collection element [all_clocks] { puts $chan [concat $element : [get_object_info -name $element]] } close $chan ---------------------------------------------------------------------- The 'all_clocks' command is not recognized (ran from the Tcl Console). I've got the following: ---------------------------------------------------------------------- Error:ERROR: Quartus Prime Tcl command "all_clocks" is only available for use in the following executables: Error: quartus_fit Error: quartus_sta Error: while executing Error:"all_clocks" Error: invoked from within Error:"foreach_in_collection element [all_clocks] { puts $chan [concat $element : [get_object_info -name $element]]}" ---------------------------------------------------------------------- So, what's the problem? How could be fixed? Thank you! --- Quote End --- Ok, so here is my complete example. Previously I just posted snippets but they need to be run in the correct context. I run this on the command line:
$(QUARTUS_BIN)/quartus_sta -t generate_timing.tcl $(DESIGN) 10 Where the contents of the file generate_timing.tcl is as follows: set projname
set numpaths
project_open $projname
create_timing_netlist
read_sdc
set_operating_conditions -model slow -grade c
update_timing_netlist
report_timing -setup -npaths $numpaths -detail path_only -file "TQ_setup_slow.rpt"
set_operating_conditions -model fast -grade c
report_timing -hold -npaths $numpaths -detail path_only -file "TQ_hold_fast.rpt"
report_exceptions -file "TQ_exceptions.rpt"
set chan
foreach_in_collection reg {
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
foreach_in_collection cell {
puts $chan ]
close $chan
set chan
foreach_in_collection pin {
puts $chan ]
close $chan
set chan
foreach_in_collection net {
puts $chan ]
close $chan
set chan
foreach_in_collection port {
puts $chan ]
close $chan
set chan
foreach_in_collection clk {
puts $chan ]
close $chan
set chan
foreach_in_collection keeper {
puts $chan ]
close $chan
exit
