8 years ago[SDC] Input/Output delay for All ports -> script writing
Hi All, How can I create the timing constraints (set_input/output_delay) for all ports (excepting clocks and reset ports)? Let's say the design has the following clocks: clk0, clk1, clk2 ...
8 years agoUse something like:
set data_inputs [all_inputs] set data_inputs [remove_from_collection [all_inputs] clk] That will create a list without clock. If you want to remove something else, do another line: set data_inputs [remove_from_collection $data_inputs reset] Repeat as necessary. If you want to visually see what's in it, then do: query_collection -all -report $data_inputs Once correct, use in constraint: set_input_delay -clock clk -max 0.0 $data_inputs Then repeat for outputs
