16 years ago
SDC constraint warning messages during synthesis
I got three things on my mind right now:
1) after finally getting a hang on how to constrain a design using TimeQuest, I run into huge amounts of warnings that are put out during synthesis, for example:
Warning: Ignored assignment: set_input_delay -add_delay -max -clock [get_clocks {inst1|altpll_component|pll|clk[2]}] 3.700 [get_ports {I2C_SDA}]
Warning: Argument <targets> is an empty collection
The same constraint works fine using TimeQuest or when the fitter is running. Now, do I get those warnings, because there is not netlist yet, from which the synthesizer can get said ports? Also, I have timing driven synthesis deactivated, still I get the error messages. I choose to ignore then, since my design seems to work as intended and TimeQuest does not find any problems later on.
2) On another note, I am really annoyed by the altera_reserved_tck constraint that is hidden in some megafunction I use (probably probe or signaltap) and that I cannot edit:
Warning: Ignored assignment: create_clock -name {altera_reserved_tck} -period 100.000 -waveform { 0.000 50.000 } [get_ports {altera_reserved_tck}]
I use this constraint I got from the support database and overwrite the hidden one and that does not produce a warning message:
create_clock -period "100.000 ns" -name {altera_reserved_tck} {altera_reserved_tck} -add
Still, is there no way to get rid of hidden constraints?
3) I sometimes get weird setup relationships on my clocks of 0ns (basically latch and launch edges are identical).This only applies to the path from a dff to an output pin. I use this constraint to generate the clock:
create_clock -name {TXCLK} -period 80.000 -waveform { 0.000 40.000 } [get_ports {TXCLK}]
which is nothing special really. The output is constrained in the skew approach (according to Altera online training) as follows:
set_output_delay -clock { TXCLK } -max 38 [get_ports {TXDATA* TXEN}] -add_delay
set_output_delay -clock { TXCLK } -min -38 [get_ports {TXDATA* TXEN}] -add_delay
Basically, an UDP/IP-streaming core I use outputs it's tx data to one row of dffs which output the data to the output pins. The hold violation of 0ns I get is from dff to output pin. This violation only happens with 12,5MHz TXCLK which is used in 10/100Mbps mode and is an external clock from the PHY. In 1000Mbps mode, the pll generated 125MHz clock is used and no violation occurs.
OK, that's all for you gurus ;) My design works fine, but I am trying to shave off the rough edges and cut down on the less important warnings during full compilation.
