9 years agoSDC - What clock should the input pin be relative to?
Hello, signal_x in an input pin to my FPGA. signal_x is synchronous to clock_x which is also an input pin. clock_x drives a pll input and becomes pll_clock_x. pll_clock_x is pha...
9 years agoyes 15 ns is plenty of margin. You might better set pll to source synchronous mode. That way the clock data offset at pins is retained by pll
