9 years agoSDC - What clock should the input pin be relative to?
Hello, signal_x in an input pin to my FPGA. signal_x is synchronous to clock_x which is also an input pin. clock_x drives a pll input and becomes pll_clock_x. pll_clock_x is pha...
9 years agoThis means io paths are failing. what are your set input delay figures.
What is the figure for setup relationship on those paths. Have you added derive_pll_clocks. what mode is the pll. you may try remove pll
