15 years agoI have trouble visualising over a hundred individual pin names.
You could place one pin (per io type), fill in a placeholder name that covers the longest name in your pin list and then copy/paste. You can then edit the saved .bdf as you would edit a HDL file. After that however you have to position the pins manually in the BDE.
