Altera_ForumHonored Contributor16 years agoschematic entry & parameters Hi, I need some hint on this issue.. I have a building block (call it A)..I use this block several times with different parameters (x,y,z)..On my top level design, I am using schematic entry......Show More
Altera_ForumHonored Contributor16 years agoThank you for the explanation - I always wondered if that was possible.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
