16 years agoI figured it out..never mind guys..
--- Quote Start --- Hi, I need some hint on this issue.. I have a building block (call it A)..I use this block several times with different parameters (x,y,z)..On my top level design, I am using schematic entry...This parameter (x) is also used in another block (call it B)....Now I am wondering is there a way I can define this parameters (x) to be a global one that applied to both A&B?.. Thanks E p.s. PARAM primitives....I was trying to use it..but no luck...any one has some experience? --- Quote End ---
