15 years agoSave NIOS II Console view to file
Hello, i'm creating a ; seperated output in the NIOS II Console with printf-function... Is there a possibilty to save this output to a file? Copy&Paste will also be fine, but is not w...
15 years agoI'm using 8.0. I found that if you launch manually Nios2-terminal.exe from a DOS prompt you can redirect output to a file with ">".
I hope this tricky is useful for you. Ciao
