9 years agoSame VHDL block RAM inferring file, different results
Hi, I have the following VHDL file to infer a true dual port, single clock block RAM. I believe that it is according to Altera's guidelines. I have Quartus 16.02 Build 222 07/20/2016. When ...
9 years agoI don't know if this is what you want to do, but to get the most optimal results in hardware without having to futz with code, you could implement the RAM using the block RAM IP core.
