9 years agoSame VHDL block RAM inferring file, different results
Hi, I have the following VHDL file to infer a true dual port, single clock block RAM. I believe that it is according to Altera's guidelines. I have Quartus 16.02 Build 222 07/20/2016. When ...
9 years agoI use Quartus 16.02 Build 222 07/20/2016.
The most annoying thing is that it produces different results in isolation and within a design. This is a very old design that worked in CycloneIII before. I'm trying to revive it in CycloneV. I am almost certain that I would have not needed to use the new data being written, otherwise I would have built bypass myself. Also, the design logic does not expect the output of the RAM be registered. As for "fastest" I mean the one that is closest to Altera's block RAM actual hardware without any additional fabric logic (i.e. for bypass).
