9 years agoRunning de1soc Vector_add example on de5-net
Hi, I was asked if I can run de1soc vector_add example on De5-net board. After I compile the Kernel when I type Make I get the following error : arm-linux-gnueabihf-g++ host/src/main.cp...
9 years agoChanging the red part alone should be enough to fix the target compiler. You should also remove the --arm switches from "AOCL_COMPILE_CONFIG" and "AOCL_LINK_CONFIG".
