9 years agoRunning de1soc Vector_add example on de5-net
Hi, I was asked if I can run de1soc vector_add example on De5-net board. After I compile the Kernel when I type Make I get the following error : arm-linux-gnueabihf-g++ host/src/main.cp...
9 years ago --- Quote Start --- I think the test examples from DE1-SoC and DE5-Net are the same, just targeting different boards. You can modify the examples from DE1-SoC manually to target DE5-Net. You should modify the makefile so that the host compiler is changed from arm-linux-gnueabihf-g++ to g++, and the target board is de5net_a7 instead of whatever it is right now. --- Quote End --- # This is a GNU Makefile.^M # It can be used to compile an OpenCL program with^M # the Altera Beta OpenCL Development Kit # See README.txt for more information.^M # You must configure ALTERAOCLSDKROOT to point the root directory of the Altera SDK for OpenCL^M # software installation. # See doc/getting_started.txt for more information on installing and^M # configuring the Altera SDK for OpenCL.^M # Creating a static library^M TARGET = vector_add^M # Where is the Altera SDK for OpenCL software?^M ifeq ($(wildcard $(ALTERAOCLSDKROOT)),)^M $(error Set ALTERAOCLSDKROOT to the root directory of the Altera SDK for OpenCL software installation)^M endif^M ifeq ($(wildcard $(ALTERAOCLSDKROOT)/host/include/CL/opencl.h),)^M $(error Set ALTERAOCLSDKROOT to the root directory of the Altera SDK for OpenCL software installation.)^M endif^M # Libraries to use, objects to compile^M SRCS = main.cpp^M SRCS_FILES = $(foreach F, $(SRCS), host/src/$(F))^M COMMON_FILES = ../common/src/AOCL_Utils.cpp^M ^M # arm cross compiler^M CROSS-COMPILE = arm-linux-gnueabihf-^M ^M # OpenCL compile and link flags.^M AOCL_COMPILE_CONFIG=$(shell aocl compile-config --arm) -I../common/inc AOCL_LINK_CONFIG=$(shell aocl link-config --arm) ^M ^M ^M # Make it all!^M all : ^M $(CROSS-COMPILE)g++ $(SRCS_FILES) $(COMMON_FILES) -o $(TARGET) $(AOCL_COMPILE_CONFIG) $(AOCL_LINK_CONFIG)^M # Standard make targets^M clean :^M @rm -f *.o $(TARGET)^M I changed the red section to g++ but it is not working. Should I delete Cross_compile ( green ) part ? Thanks,
