9 years agoRunning de1soc Vector_add example on de5-net
Hi, I was asked if I can run de1soc vector_add example on De5-net board. After I compile the Kernel when I type Make I get the following error : arm-linux-gnueabihf-g++ host/src/main.cp...
9 years ago --- Quote Start --- If you are trying to use the example shipped with the Terasic SoC board, it is obviously not going to work on DE5-Net since the latter is not an SoC board. The example will, by default, compile the host code for ARM, while for DE5-Net you should compile the host code for a standard x86/x64 CPU. Use the x64 version of the benchmark provided here: https://www.altera.com/support/support-resources/design-examples/design-software/opencl/vector-addition.html P.S. The error you are getting above is due to the necessary ARM cross-compiler not being available on your system. You should install the necessary packages if you want to cross-compile for ARM. You can easily find the package names by searching google for the missing file. Obviously, this is not needed if you are targeting the DE5-Net board. --- Quote End --- Thanks for your response. I have run DE5-Net test examples successfully on the Machine. But I was asked if it is possible to run de1soc test examples on DE5-Net. So based on your comments it is not possible. Is that correct?
