12 years agoAh, thanks for the clarification.
I get just the Java error when I launch qsys-edit from the network-mounted tools:
java.lang.RuntimeException: Can't initialize DevFamilyManagerFromDB
at com.altera.infrastructure.devices.DevFamilyManagerFromDB.<init>(Unknown Source)
at com.altera.infrastructure.devices.DevFamilyManager.<init>(Unknown Source)
at com.altera.infrastructure.devices.DevFamilyManager.getInstance(Unknown Source)
at com.altera.sopcmodel.ensemble.Ensemble.customizeParameterDescriptors(Ensemble.java:2967)
at com.altera.sopcmodel.beanelement.BeanElement.ensureParameterDescriptorMap(BeanElement.java:160)
at com.altera.sopcmodel.beanelement.BeanElement.getParameterDescriptors(BeanElement.java:136)
at com.altera.sopcmodel.beanelement.BeanElementClass.newInstance(BeanElementClass.java:286)
at com.altera.sopcmodel.ensemble.Ensemble.createQsys(Ensemble.java:586)
at com.altera.sopceditor.util.EditorUtils.createNewEnsemble(EditorUtils.java:1296)
at com.altera.ipedit.QsysEditorApp.createEditor(QsysEditorApp.java:345)
at com.altera.ipedit.QsysEditorApp.runQsysEditor(QsysEditorApp.java:315)
at com.altera.ipedit.QsysEditorApp.act(QsysEditorApp.java:226)
at com.altera.utilities.AltCmdLineToolBase.runTheTool(AltCmdLineToolBase.java:640)
at com.altera.ipedit.QsysEditorApp.main(QsysEditorApp.java:455)
Caused by: com.altera.infrastructure.devices.DeviceDBEnvironmentException: Can't initialize connection to /mnt/cas_nfs/applications/altera/13.1/quartus/common/devinfo/device.db
at com.altera.infrastructure.devices.SQLQueryRunner.connect(Unknown Source)
at com.altera.infrastructure.devices.DeviceDB.initConnectionToDatabaseFile(Unknown Source)
at com.altera.infrastructure.devices.DeviceDB.<init>(Unknown Source)
... 14 more
Caused by: java.sql.SQLException: com.altera.jdbcsqlite.Exception: disk I/O error
at com.altera.jdbcsqlite.JDBCStatement.executeQuery(JDBCStatement.java:153)
at com.altera.jdbcsqlite.JDBCStatement.executeQuery(JDBCStatement.java:168)
at com.altera.jdbcsqlite.JDBCStatement.execute(JDBCStatement.java:173)
at com.altera.infrastructure.devices.SQLQueryRunner.initializeUnencryptedConnection(Unknown Source)
... 17 more
Caused by: com.altera.jdbcsqlite.Exception: disk I/O error
at com.altera.jdbcsqlite.Database.vm_compile(Native Method)
at com.altera.jdbcsqlite.Database.compile(Database.java:684)
at com.altera.jdbcsqlite.Database.get_table(Database.java:308)
at com.altera.jdbcsqlite.JDBCStatement.executeQuery(JDBCStatement.java:120)
... 20 more
So this suggests that system generation is failing, and hence the rest of the compile isn't working?
