12 years agoActually I was just thinking "qsys-edit" because that launches the tool. I just want to verify the tool is working properly because OpenCL is dependent on it. If Qsys doesn't even launch correctly then it would make sense to switch over to debugging that. Qsys is lumped into Quartus so that's the subforum most people use for Qsys questions but before doing that I would check to see if it's launch correctly since I haven't ruled out OpenCL yet.
I think what you are referring to is how OpenCL is using Qsys which is a little different. If Qsys isn't behaving then that line command line will not work either.
