12 years agoThanks for the reply. To be clear, when you say run qsys, do you mean something like:
qsys-script --script=system.tcl --Xmx512M --XX:+UseSerialGC --system-file=system.qsys
After using the -c option on the project to just generate the project files. If this is the case, then yes, I get the same error. Is there a dedicated qsys forum that I should maybe be bothering;) ?
