12 years agoThis might be an issue outside of OpenCL. Try launching Qsys directly by running 'qsys-edit' assuming you have the Quartus /bin directly in your path. If you are on Windows you can use the Nios II command line shell to launch Qsys. If there is a Qsys issue I'm expecting there to be a bunch of errors at the bottom of the GUI.
