10 years agoRunning a console executable from a tcl script
Hi there I am attempting to call a console executable file from a tcl script that should run before every compile. Here are a few iterations that I have tried, but nothing seems to make the tcl...
10 years agoYou'll get the results you describe if your executable doesn't produce any output to STDOUT.
Your script snippet works fine here. Changing your cmd variable to instead use Windows cmd.exe to run the "set" command, you get your environment dumped into Quartus messages.
set cmd "cmd /c set"
post_message "cmd: ${cmd}"
if { } {
post_message -type error "couldn't run $cmd"
} else {
post_message -type info "Command \"$cmd\" successful."
If something basic as this doesn't work for you, not sure what next? Reinstall? If this works, then there's a problem with your .exe, or there is a problem executing your .exe from a script like this.
